Hello together. I have several problems with my Fairphone 3+.
the fingerprint sensor does not work. There is always a message that it is dirty. Even when I have just cleaned it. I wanted to perform a test via the maintenance menu, but this is also not possible.
for two days the pedometer has also stopped working (since 12.02.). I tested this with two different apps, SHealth and pedometer, both did not work. I use Android 10.
Is this error known and is there a way to fix it? Thank you very much.
best regards
Chio
