Problems with App Lounge in anonuymous mode
Hey there! Im having some problems installing an app from App lounge in Anonymous mode. My device says “account unavailable” when I log into App lounge and it tells me to “update my session” but nothing really happens when I select that option.
Also, when I actually try to download the app its just stalling without any progress.
I have tried to clear the storage and cache for App lounge, without any success :frowning:
Does anyone know what more to try?
when you encountred issues with AppLouge, easiest is to use “F-droid” + “AuroraStore” instead, as AppLounge is basically an addition of both…
Okay, but I cant download those either (not from the App lounge at least). Is there another way maybe? (im not a developer here…)
you can simply follow the above links to download, then the file manager to install
okay sorry for that - i was on desktop while i read it so i didnt even try to follow the links. Do you know if there are apps that are NOT available in F-droid, but eligeble for download in App lounge/Google play store? Or should it be the same in all places? (the app im trying to install is not showing in F-droid, and its sort of a “commonly used app”).
F-droid is the main Open Sources app store.
Aurora is an alternative client for the mainstream Gogol Play app store. (you will need to black-list all android default apps other than those you have personally install).
