Hi Folks,
After few days using /e/ on my FP3 I still have one problem. The microphone doesn’t work in apps like Signal or Telegram. It works in every other apps Phone, Recorder … permissions are ok for signal and telegram.
Have you the same behavior ?
Did you find a workaround ?
Regards,
