stupid me, the module is called thinkpad_acpi, isnāt it:
simon@laptop:/sys/module$ cat thinkpad_acpi/parameters/fan_control
N
so that doesnāt look exactly like a 1ā¦
Should the file in /etc/modprobe.d/acpid.conf and itās content then be changed to thinkpad_acpi as well? On the other hand ps does show an acpid (which simply could be a daemon to control something):
Well, thereās a difference between the process name and the module name. They donāt need to be in sync, actually, they wonāt be in sync. Acpid is the (generic) process for handling acpi events, and the module thinkpad_acpi understands your hardware and translates its events to the generic acpi implementation (might be simplified, but this should be itā¦)
So, the filename acpid.conf is irrelevant (except for itās location and the suffix .conf), BUT, inside, the options will have to be
N, I would expect, means ānoā, so, no fan control (what ever this means⦠Might be that the bios is in charge, and no operating system based program, might be it means no fan control at all⦠I really donāt know⦠Just give it a try with 1, or even Y
I did two reboots, trying 1 and Y. Both led to Y in thinkpad_acpi/parameters/fan_control and now I can again echo any level value without any error message, but still also without any effect. cat-ing always shows level 1 and 250rpmā¦
So fan control doesnāt seem to work.
yes, sounds like itās broken. Only one thing. When you started compiling, did the fan actually get faster (acustically), or did the fan sound like always turning at the same speed?
It always stays at level 1, which is not even noticeable. Thus later on the throttling kicks in. Iāll try to see if I can do the uefi update tomorrow to see if it changes anything.
This is really getting off-topic in here but the Thinkpads normally have an embedded controller which handles fan control independent of the OS. If you override this by loading some module though you better be sure that it really does what itās supposed to beā¦at least this would explain the build failures perfectly.
I assumed so as well. Unfortunately as explained above the fan doesnāt react at all to different CPU loads, leading the CPU to throttle during compilation.
Well so far it does (unfortunately) nothing. :-/
Well one theory was that the throttling caused the segfault and thus the idea to manually try to speed up the fan (which didnāt work). Thus so far we couldnāt verify this theory. If you have an idea for another cause and how to test it, let me know. Iām kind of frustrated by nowā¦
Well, but itās possible your machine suffers in general from an overheating problem due to bad application of thermal paste:
Yet one thing you could try is set the cpu governor to powersave to force it to stay in the low frequency regions. Would take much longer to compile this way I guess but could workaround the issue.
While it obviously can be the fact that the thermal paste was badly applied in my laptop I havenāt experienced any other issues so far (please be also aware that the Yoga 13 is an ideapad, while the Yoga 12 is a thinkpad ā so no idea how similar the production steps are at all).
I have tried to change the governor before, but it doesnāt support any other than the one it uses if I recall correctly.
Iāll try to collect some experience from other Yoga 12 owners in thinkpad forums to see how the fan works for them.
Itās just a brand name, quality and investors change. Maybe sending it in for service is also a good approach. If it is out of warranty have a look yourself (p. 81)
Also possible: Get cheap used desktop hardware as a headless build server you can use with ssh.
Agree. What I wanted to say is that there is not much relation between the Yoga 13 and 12. If it it wasnāt a single incident reported on the forum you linked, but a line problem, it still probably wouldnāt effect the 12 ā I believe.
If nothing else helps it might worth a try. Itās younger than a year, so shouldnāt be a problem.
But as mentioned before first Iād like to update the UEFI (which apparently doesnāt work via USB, but only via CD) and to check with other owners if I find some in a thinkpad forum.
I would like to not have to. I hoped that my laptop could fulfil all my needs.
Just for reference, I did the UEFI update to 1.22 and now itās actually the first time ever that I hear the fan of the laptop. Nevertheless sensors and cat /proc/acpi/ibm/fan still only show level 1 and 257rpmā¦
Anyway, I hope that this has fixed all thermal issues (still Iām wondering if I should contact support as in the process of trying out building the glue of the rubber feet has melted away and probably the pcb/soldering points donāt like the extreme temperature differences either). Iāll give compiling a new try soon⦠Thanks to everybody who has helped out so far.
Edit: After more than 7h I finally successfully completed my first build.
