a black disc has appeared on my fairphone 6 screen a few weeks ago and seems to increase in size over time, hiding more and more of the display. has anyone experienced something similar? what is the fix? I suppose I need to change the screen?
Thank you for your advices. I didn’t know about this app. The screenshots don’t show the the black disc but you can see it on this photo taken with another phone
For me it looks like a weird bug taking the camera hole in that position. I can not think of a way to prove my theory but maybe you can ask support via chat. They might ask a factory reset.
that’s what I am afraid of… if I change the display, the black spot might still be there… but how can an app make such a change that does survive a reboot…
it is slightly bigger than the camera hole and it looks like it is growing over time… I’ll try the factory reset, that seems a good idea, if I can find how to do it…
Was there any way found to get rid of the Problem?
Have the Same issue. Same Spot, Same location. From Position and Size to me it Looks as If they Position of the Camera hole got “rotated” in Software while rotating the Screen.
It already is there on the First screen, when starting Up the Phone.
That sounds like a damaged display, especially since the spot is getting larger over time. I’d get it checked by Fairphone support before replacing the screen, as they may confirm whether the display needs to be replaced.
