Every time that I try to download an App, my phone gives an error (nr 941). If I try it again, it works without problems… How can I fix this?
A quick search seems to suggest it’s a problem related to cache; the suggestion being to clear cache in both Play Store and Download Manager and see if that helps. I can’t vouch for the solution but a lot of the top search results pertain to cache, so hope it helps
Edit: ninja’d by @Lidwien!
Thanks for the fast reply! The last solution worked (“Uninstall play updates”). Thanks again!
Workaround suggested that works for this problem. This topic is now closed. New replies are no longer allowed.
