With my fairphone 4 my datas don’t work well. Sometimes it’s working and then no… Without reason .
Any ideas?
Thanks
Any ideas?
Thanks
I assume you are referring to your mobile data.
Have you gone through the Fairphone troubleshoot?
Also what is your data provider?
Could you give some background?
Do you have two SIMs?
Does the mobile data connection work better in some areas?
How long have you
