Problem unlocking FP6
I tried installing LineageOS to my Fairphone 6. I followed the instructions as the guide said ( Install LineageOS on FP6 | LineageOS Wiki ). I read 2 topics about istalation LineageOS & didn’t found any helpfull information
Current firmware: Android 16 (stock FP6.QREL OS)
Steps taken so far:
By using this official guide https://support.fairphone.com/hc/en-us/articles/10492476238865-How-to-unlock-or-lock-your-Fairphone-s-bootloader I get to part 2 Unlock the system via your computer. The adb reboot bootloader forsing phone to rebot to fastboot mode. After this, according to instructions, I was trying to use fastboot flashing unlock but didn’t get much sucess & get this on my screen:
My question: Looks like somebody used this instruction to flash FP6 to LineageOS & could give me some tips to jump over explained problem.
Did you enable OEM unlock in the Developers option?
What PC system do you use? With windows aften bootloader driver are missing
Yes, defenetly.
Use Linux pc for unlocking, windows fastboot adb drivers are a dumpster fire
Thank you for idea. I’ll check it in nearest days.
Yes my PC system is Windows.
It’s harder than it coud be. Sadly, but I didn’t have experience with Linux.
It helped me partly. I really install some missing drivers though Windows Update & get ability to fastboot flashing unlock . After that phone restarts, wipes all data & now not mentioned in the adb devices. So I couldn’t use fastboot flashing unlock_critical to finalize unlocking. By the way, I install the latest OS update after wiping all data, But it didn’t helped.
Maybe somebody have any idea that I have next issue?
ADB devices? Thats not needed for astboot? So could you elaborate if you are in bootloader/fastboot mode and still fastboot commands dont work?
No, I was not in bootloader because I couldn’t enter to it from ADB.
You can enter it without adb. Start using Power and Vol - simultanously
Did you reanable USB debugging?
Exactly. It was the point. I forget to reanable USB debugging.
Now everything fine & I get success with installation new OS. Many thanks for help.
Gust want to know you last small advice: how to check does the MindTheGapps were installed correctly?
And finally, when I was locking back fastboot flashing, I get totally unloading device with such on the screen. Now by using adb devices it is not mention the phone in the list & give such message on screen:
Did you here obout this problem before on this forum or maybe you have and idea how to fix it?
You cant lock when using Lineage. Can you unlock again?
Yeap, I get scuscess.
In tha fastboot I found “Alternative bootloader” or something similar option. Though that one I get to Linage OS recovery fastboot & install again the Linege OS & MindTheGapps.
Many thanks for your advices! Real Fairphone Angel)
