Problem connecting to WiFi Enterprise with PEAP
Hi there, I can not connect to a Enterprise WiFi with PEAP, the “Connect” Button stays gray.
There is a description in german with screenshots here
The workaround mentioned there (installing a WiFi Manger, in my case this one) is working but I do not really want to use an external app for using WiFi if there is an easy solution for this.
Well, if I got the workaround correct, you do need the WiFi manager just once for entering the connection data. Once that’s done, it is implemented in the Android system and you can delete the app again.
Therefore, if you have followed the workaround instructions and can connect now, delete the WiFi manager and everything should be fine.
Yes that’s a possibility.
So see my post as a tip for a workaround for everyone running into this problem.
This topic was automatically closed after 183 days. New replies are no longer allowed.
