Prevent mobile network name from continuously scrolling
Hi, I am using a Fairphone 5 in France. The name of the mobile network operator is quite long (Bouygues Telecom), so it keeps scrolling endlessly in the upper left corner of the screen. Sure, I can live with that but if there’s a way to prevent it from sliding over and over again it would be better as a moving feature catches your gaze automatically. Thanks for your time. Best. J.
I had the same problem (‘ecotalk Wi-Fi calling’). Under “Settings / Display” there is an option to “Display network name in status bar”. This can be turned off!
Thanks for the trick
