Ok, just found out, how to mark keys here on the forum.
Solution is to use the <kbd>-tag.
Example: <kbd>keys</kbd>
And what does this do @Stefan?
You mean the âkbdâ-Tag? E.g. you can tell someone to press Ctrl+c simultaneously.
I was trying to insert coloured text, but didnât succeedâŚ
Just checking if RSS feeds work for a topicâŚ
Edit: OK so you can add â.rssâ to any topic, copy the resulting url into a RSS reader and follow it through rss. Example: https://forum.fairphone.com/t/playground-features-of-this-forum/28.rss
See more (very recent discussion):
https://meta.discourse.org/t/feed-of-new-posts-topics-replies/15102/5
This topic is now unlisted. It will no longer be displayed in any topic lists. The only way to access this topic is via direct link.
This topic is now listed. It will be displayed in topic lists.
https://twitter.com/NewLuck77/status/595980779777368064
PS.: Displaying Tweets doesnât work because the Fairphone Forum doesnât allow for Twitter-login.
Testing new polls feature.
0 voters
0 voters
0 voters
Does anybody know why this
- Text
- Text
- Text
Sometimes leads to this:
and sometimes to this:
Itâs quite annoying if you want to use it more than once in a post and it looks different every time.
It might depend on whatâs before the list. Cause if you donât start with a headline, the list isnât rendered at all:
-Text
Yeah but take a look here:
I donât see what could possibly be different in the lists.
EDIT: Correction: Only the first sub list is rendered without the additional line break.
Must be a bug in the Discourse software.
Or its meant just for lists without any line breaks, eg:
but if you add a line break after the 3rd âtextâ:
Text
Text
Text
Text
Text
Text
Can I do an in-post poll?
0 voters
in a post one can either reply to the post or reply to a replyâŚ
My posts are shown with all the replies just under each other, not in any hierarchy. Is this possible? I have searched the preferences and not found anything.
