Currently, the menu bar of the forum (All categories // Latest // New (18) // Unread (7) // Top // Categories // Bookmarks) displays beneath the bar with the search, hamburger menu and user icon. It would be great if the menu could be placed in the same bar as search/user icon.
Currently, the forum menu/categories disappear when scrolling down the page, whilst placing them in the bar together with the search would keep them always visible.
Yup, that’s what I meant
Advantages: do stuff with one click less indeed (didn’t check the hamburger menu tbh), but most importantly (for me) it provides an indication of where you are. It also increases discoverability, allows you to create a new issue if you find out at the bottom that the current thread doesn’t cover your problem and saves vertical screen space.
@Stefan: I guess @glotzbach is not talking about the bar while reading posts in a topic but while looking at the topics overview on the forum’s homepage. If you choose a category there to only see the topics in this category, you won’t see which category you are in anymore after having scrolled down.
Thank you for pointing me towards an inconsistency A) on a thread page, the page info/title does get moved into the same bar as search/user icon. B) on a category page, the page info does not get moved into that bar. Additionally, on a category page there’s no Fairphone logo on the top if scrolled down (there is on a thread page).
I think you should direct this request to https://meta.discourse.org/ . The developers of Discourse (the forum software we use) are present their and can tell you more about the feasibility of your request. (You are right, it would be more consistent, if there would be a headline (e.g. “Latest Topics”, if you are in the Latest tab.)).
I removed “FR:” from the topic title because it looked as if this topic was in French language.
