Physical layout
I found no complete description of the physical layout of the Fairphone 6.
These things are missing from the description in the manual, they all concern items on the outside rim:
— there is a small hole at the top right: what is it? I accidentally stuck the card tray pin in it. I hope I did not damange anything.
— there is a small hole at the bottom left (next to the equally small hole for removing the card tray). That is the microphone, but its existence and placement is not mentioned in the manual.
— there are three oblong larger holes at the bottom right, they are the speaker, but they are also not mentioned on the diagram in the manual.
Those are Microphone and Loudspeaker outlets
OK, so what is the top right one?
This is also a microphone.
You need two microphones to record stereo audio in videos.
Thanks.
I hope Fairphone will update the description.
