I have always been, well, at least, content with my FP1, even after 3 years. Now, for about a month, I haven’t been able to properly use the phone as a phone (i.e. to make phone calls) anymore. When it first started, I thought it was due to bad service, because just like when you have bad service I only hear the voice of the other person interruptedly, but they can hear me perfectly fine. But I’ve encountered this problem multiple times now, even in places where I know I have good service, because I made phone calls from there before, so I figure it must be something about the phone itself. Is anyone encountering the same problem or has an idea, what I could do about that?
The same problem with my FP1. I have dual SIM (2 different providers) and some weeks ago I did the necessary storage upgrade. After a while I began noticing very poor GSM coverage. In buildings there’s often no connection at all. At this moment my phone is more than 50% of the time without collphone reception. Sometimes it helps turning on and of Wifi or 3G. A very annoying situation. Suggestions?
@Dries_Brugge: Do you also hear the other person’s voice interruptedly?
@littlesis92 I think I didn’t read properly. I overread, that your voice is transmitted fine, but it’s the other person’s voice that is not transmitted uninterruptedly.
@both In #dic:testingmode you can make a complete factory test. Please do so and post the result (maybe a photo).
I can’t take a picture, but the results are:
[0] keys
[0] touch pa…
[0] eMMC
[0] Memory Card
[x] SIM Detection
[x] Signaling T…
[0] RTC
[0] Loopba…
[0] Receiver
[x] main camera
[x] sub camera
[0] GPS
[ ] FM Radio
[x] Bluetooth
[o] Wi-Fi
[x] Battery & …
The rows with [0] are green, the ones with [x] red and the one with [ ] ist black. It cuts off the rows and doesn’t wrap the words, so I put “…” when that happened.
