Gelein
December 2, 2018, 8:21pm
1
I installed Android 7.1 on my Fairphone2. It worked perfect for sometime, but since a few days I can’t power off anymore; it always reboot when I select ‘power off’.
Hello,I have the same problem since the last update this afternoon,only restart,no more switch off while I select switch off…
Please both find the solution here (“Power issues”, first point):
Here’s an overview of what crops up most often on the forum:
Most annoying Bugs
Note that where workarounds are listed, these are not meant as a permanent solution. In other words, Fairphone should/will come up with a permanent fix. The workarounds are provided as a temporary measure. A statement by Fairphone about future updates can be found here .
If you are affected by any of these issues, please add any useful new information on the official bug tracker. If you don’t have anything to add, b…
