I have this on apps that connect to the internet and need the screen alive, so I set the screen timeout to 30 min.
While this workaround might work it’s an ugly one because the screen is the component that eats the most energy for sure on the FP2, probably also on the FP3. But @HannahD1 could give it a try for sure.
Hi Fairphone friends, just to say that I gave up… The problem persists and the people at the app aren’t replying anymore. So I ended my subscription and uninstalled the app. Will now start trying other meditation / mindfulness apps, if I encounter the same problem there I know where to find you Thank you so much for your help, really appreciate it.
