Hi. My phone has started spontaneously muting when playing podcasts, Spotify or iplayer. I listen connected to a speaker via Bluetooth - the headphone socket doesn’t work so I can’t check whether it would still do it if I wasn’t using Bluetooth. I’ve not noticed any patterns in when this happens. Any ideas of what I could try?
Thanks very much
You mean, it mutes output when you start playing, not some time in between listening to your podcast? Does it happen same way, when you play with another application, e.g. VLC instead of AntennaPod or similar?
