I often use my FP2 in my car for playing music. And I want the screen to stay on while the phone is in the car. Thats easy? Develpoers options and “stay on”? Yes, I have checked that and the display stays on, but dims after the normal locktime and I can see no playlist anymore - to dark. There must be an option that the screen never dims …
I got it but that’s an absolute brightness-level. It could be, that I have set the brightness to a mid-level and after some time the “dim-function” kicks in and sets the brightness to a higher level. I need the “dim-function” itself and a killer for it …
did you inactivate the “automatically adjust brightness” option? might solve your problem to have the brightness really low all the time you want it that way…
This feature works best on my phone and I won’t miss it.[quote=“cortomalese, post:7, topic:17305”]
Triggers to activate: Charging
Action: screen on
[/quote]
Screen is on while charging without Macro.
You better try searching for a Xposed Module that adds this capability to the Android system. Wiko’s developers added it manually, it’s not an option included on Android Open Source Project (yet), the base system Fairphone OS is based on.
I don’t know, AOSP’s base code is huge. Maybe it’s declared on some plaintext config file you can edit manually or maybe it should be modified by changing the code and recompiling the system.
An app developer can require the system to keep the screen awake with a manifest permission. Enabling this is out of your power as an app user.
