Phone not showing latest OS?
If I google Fairphone latest OS, I get the following …
“Fairphone OS version 19.02.1 is the latest software version for your Fairphone 2 released in February 2019. It is based on Android 7.1.”
The above is stated at the following URL …
So, is the above definitely the latest update ? (I’m in UK, incidentally)
However, when I follow the instructions, my phone says it is up-to-date, and that there isn’t an update available.
It also says that if the app does not show an available update, there is a manual process.
My question - Why doesn’t my app show the available update?
Yes 19.02.1 is definitely the latest update. Which version do you have right now? You can see it in Settings > About the phone > Build number.
In settings /about …
Android: 6.0.1
Build: FP2-gms-18.04.1 release-keys
In application “Updater”, Current version FAIRPHONE OS 18.04.1 (Your operating system is up-to-date)
So why?
Did you try to delete cache and data of the updater app?
No, but I’ve just done that - no difference.
And is the updater itself up to date? If automatic app updates is disabled, you might still have an older version. Alternatively, you could try your hands on a more manual install of course.
It not being up-to-date seems to be the most common cause for the updating not showing. If in doubt, try (re)installing the latest version. As mentioned in the support article you found:
Make sure to have the latest version of your Updater app installed. You can do this via the Google Play store or manually, if you are not a Google user.
Yup, that’s the kiddy alright, that did the trick.
I see now that Enable AutoUpdate was not set. I wonder if this was a default? No matter, all done.
Thank you very much, everyone.
Fairphone always FTW. Fairphone for ever. Credo.
