Whenever I charge my FP2 I can not use it. That is, the screen locks and does not react to my touches. I need to disconnect the charger, switch the screen off and on, and that is quite cumbersome.
Anyone recognize this?
It is a common phenomenon that usually appears when cheap charging cables (without an “earth” line, a ground wire) are used. Try other cables.
If you want to discuss this further, to avoid duplicate topics please continue here:
