Phone encrypted: how to change passphrase?
I successfully encrypted my FP2. But I cannot change the encryption pass phrase at Settings > Security. Any ideas? Thanks.
I think you have to go to Settings > Security > Screen Lock, type in your current lock, choose the new locking method and then type in the new pin/password/pattern. But I never used encryption, so it may be different.
Yes it works as you said! Earlier there was a separate menu for encryption.Thanks a lot!
Yeah that other menu is just for setting up the encryption itself.
Glad it works. :slightly_smiling:
