Phone "dies" when adjusting volume during call
My FP1 shuts down (not completely, but both sims lose connection, i.e. the call is lost) each time I change the volume via the buttons on the side during a call. Anyone with the same problem or an idea of how to fix it?
Some people have reported similar problems:
https://forum.fairphone.com/t/changing-volume-during-phone-call-completely-crashes-fairphone-1/10216?source_topic_id=20789
Is your’s related?
PS: Fairphone will release a software update in September. Some issues should not be present in the new version.
Thanks a lot, I will try to disable the mood screen and see if it helps :slight_smile:
