I have an FP1U since about 3.5 years and am very happy with it.
But two weeks ago, my phone stuck during startup.
So i tried to make a eMMC Reset.
During this process, the battery fell out,so the process interrupted.
Now I even cannot access the boot-menu by pressing [Volume Up & Power On]
The phone does not react at all, and is even not detectable as USB-Device with any kind of OS.
Is there anything I can do to save my phone?
Does anyone has an idea?
Thanks a lot for your response and best regards
Hannes
If you see not light when your phone is connected to the charger, then it could be that your battery is fault or your usb-connector.
Perhaps there’s somebody having a Fairphone 1 in your neighbourhood, so that you can have your phone tested with another working battery.
May I ask where you live?
That would be my guess as well.
My FP1 battery died on really short notice as well. From one day to the next, there was no more charging.
And if @hafisch dropped the battery, that may very well have “done the trick” to put a sudden end to the batteries suffering.
I guess your advice is the best way to proceed.
@hafisch could make use of the fairphone community map to locate someone able to help:
I wonder if that map could somehow be placed more “prominent”, as I just stumbled over it when looking up, what a fairphone angel is.
If the battery is dead, the charging LED won’t flash.[quote=“hafisch, post:9, topic:31761”]
Is there a way to restore the phone if the Boot-Mode (Power & Volume Up Button) are not working anymore?
[/quote]
