Pairing FP5 with my car
With the last update of Android 14, I have bluethooth pairing each time I am using my car,
and not only on my car BMW but same troubles with the Renault car of my daugther.
My daugther gets a samsung S24 and on my car and daughter car the bluethooth paring is not lost. My wife gets an iPhone the pairing is perfect also, never lossted too…
I think I am going to garbage my FP5, Where is the support of Fairphone when it is under the
warranty less the one year.
Fairphone company are below everything. Good luck with this kind of european company.
I’ll try to ignore your useless claptrap…
I have FP5 now 503 days, and never have any problem with Bluetooth (different earbuds (JLab, Lenovo, MPow), speakers (Wavemaster, EnergySistem)), so your problem sure is not generic…
In my BMW (with aftermarket Dasaita/HotAudio Android Radio) too not having any problem, not before, not after latest update…
So try generic steps, remove pairing from radio and phone, a try repair again…
Just adding that in my case Fairphone 5 Bluetooth experience was the exact opposite. It works with my bose heaset, my pc, skoda car system, my panasonic sound system and even the Qualcomm aptX codec worked :slight_smile:
Thank you for all answers.
I am going to change it for an other phone I have other troubles with this phone 8 months old. I spend to much time to fix troubles of this phone, with no support it is unsupportable any more.
Good luch with this kind of smartphone.
Regards.
Just telling you that you could try the live chat. Its currently open :slight_smile:
https://support.fairphone.com/hc/en-us
For sure, that you very much for your answer, maybe I know some FP5 are working but
my is not, and not only a pairing earpiece too is not working, and I hope for this price
I get an anwser (8 months old) from support, nothing I have only some response like in this forum, look at this link, make a test, etc… I don’t to spend time to wait an answer
like I am waiting for service under warranty. Fairphone company do not assume a good
support, for me it is closed.
But I am going to write to all large resellers in my country to discribe my problem with
no correct support.
Regards.
