My FP4 battery is holding up well during the day with normal use but has started draining to around 40% from fully charged overnight, the previous drain had been 5-10% loss. I’ve tried rebooting, clearing caches etc but it seems to be persisting. Any thoughts?
I’m having the same experience. It doesn’t seem to be app-related, so it’s probably a system bug (overnight battery drain was also an issue with some previous versions of the operating system).
I’m glad it’s not just me anyway! It’s showing as being mostly system apps causing the drain so the system bug idea makes sense. Hopefully they’ll patch it soon.
I had the same issue for a while a few weeks back. Then, for no apparent reason, it went back to lower overnight battery use again. All I can say is that it did not seem to be related to an OS update for me and also reboots did not change it.
I still have no clue as to what the cause was. ![]()
Thanks. Fingers crossed it clears itself then.
Same here (The Netherlands)! Very annoying, I have to charge my FP4 at ca 18:00 coming from from full battery in the morning. I remember there was a similiar battery drain when I used Lineage OS. Now i’m on e/os, which solved the problem, but now the problem is back ![]()
In contrast to you guys, I’m not so confident that this will be magically solved. Can’t we issue this problem somewhere?
I’ve tried contacting support but they seem convinced it’s hardware rather than OS and want the phone sending in for repair. I’m sceptical because the drain is all overnight and system apps. It’s fine on normal use during the day.
My usual question: Did you check with BBS reloaded if you can find out what process or device exactly uses the power?
It’s gone., I don’t know what happened. No software update, no differences in settings, just suddenly the battery drain is gone. In the battery drain, Battery management said 25% was used on system apps. Now, it’s only 9%.
Hopefully it stays this way. How is the situation with you guys? Still experiencing the drain?
Fingers crossed! Mine’s still draining quickly overnight but the battery is behaving normally during daytime use so I guess it could be worse. Hopefully whatever magic sorted yours will reach mine soon ![]()
Still mixed experience for me: In some nights it drains over 60%, some only 10-20%. The battery saver does not seem to make a difference. Maybe airplane mode does, but I don’t have enough data on that, yet.
I got two nights with drains down to 0℅ (draining at least 30%) with airplane mode active every night.
My FP4 sometimes lost power quite quickly, not only overnight. Sometimes it happened, that even connected with an USB 2.0 it lost power instead of being charged. Only a quickloader was able to charge the phone. But a reboot normally solved that problem. In the last few days, the battery drain was higher, but not so bad. I checked the app usage with the build in Akku-control (by the way, it got worse with every Android update), and found QuickStep at the top of the list. But some hours later, QuickStep went down the list, and the battery kept the power better. No clue, why QuickStep needs so much power, although the phone was not used.
I’m also still experiencing problems. But it differs day by day. Yesterday I came from full battery (08:00 am) and phone was empty at 18:00 without using it much. Today is much better for some reason.
I also have problems with charging - slow charging is actually emptying the battery.
I’m on e/os 4.4.2
Strangely, no one knows where this behaviour comes from? When my battery is draining, my battery-usage app is reporting very high ‘system apps’ activity. I can’t see, however, what those system apps are and what they are doing…
Mine’s still draining badly overnight. I’ve tried contacting support but they don’t seem to have any ideas, I’ve sent several screenshots showing the overnight drain graphs and the fact that it’s mostly system apps but I don’t seem to be getting anywhere with a ticket that’s now been open for weeks…
I’ve switched the battery back to the first one the phone came with - I had bought a new one 2 years ago that I used since. Since then I could not see a bad battery drain over night any more.
(Neither battery looks bloated or shows any other exterior signs of damage.)
Still need to monitor for a longer time but your suggestion might hint for a solution:
Turned the phone off, took the battery out, reinserted it, turned it on again.
Last night I only lost similar as during the day without using it approx 1% per hour. Prior to that: 30-50% per night.
So let’s see whether this rather easy solution works. I’ll keep you posted.
Last night only two percent loss
So the above mentioned seems to be a solution for me.
This is super hard to debug. Sometimes it can be your provider playing with tower settings. Sometimes, it might be an app that receives many notifications because your friends chat like crazy… And sometimes it’s a plain bug in the system or some app.
Definitely worth a try then! Thanks for sharing.
