Since the update to Fairphone Open 18.10.0 I need to enable USB debugging to charge my phone’s battery from a PC. It will continue charging after disabling the option again, but then I have to redo this every time I want to charge the phone from a PC. Are there other people with this problem and did anyone solve this permanently without keeping USB debugging enabled?
Yes, thanks. I guess it’s the same issue. Hopefully they’ll find a solution.
