Hi
I started looking for threads on similar problems for my phone, but there are several at once, so hence a new thread.
- camera problems:
When I want to take a picture the screen stays black and says - no connection-
If I keep on trying to start up the camera, the phone tends to reboot. After it started up again the battery starts to plumnit down ( like 1% every 3-5 seconds). The phone also keeps on rebooting until the battery is depleted or when I plug it in.
- Screen problems:
At random use, vertical lines start to show up from top to bottom and fill the entire screen, like a stretched barcode. Remarkably, the hour indication/clock stays visible through the lines. It then dims down to a black screen. I have to put the phone off-and-on to be able to work with it again.
This problem is often followed by a reboot loop and depletion of battery life.
Can someone recognize this problem and tell me what to do to fix it?
Greets
A
