@dk1978 Thank you very much for your contributions!
do we have a dedicated thread (or something) for systematic testing? i installed the microG build and did not yet find any problems, however I did not search for them
There are now 2 different versions of the bootloader unlock code, AFAIK it should depend of which OS version you had. See this post : Bootloader Unlocking Code for Fairphone 3 not working - #8 by _tmp
I can confirm this, even though they were not reboots but complete crashes. On the official microG LOS this happened to me twice during a teleconference. The screen went black and the only thing to wake it up again was a force reboot into fastboot mode. Strangely enough, this did not happen on other long calls. Still, I fear this problem is not one with the ROM, but with the FP3 in general.
Atm. Iām running the latest FP-OS (build 8901.2A.0054.20200929) and Iām quite happy with the included camera app (version 2.0.002). Which camera may I expect in the official LOS 16.0 for the FP3?
It is a rather basic one. However, you might want to check out this Thread, where a couple of pixel cam ports are shared. These produce in some cases even better results than the FP3 stock cam. I have tried some of them on LOS and can confirm they work.
Thank You and all persons involved so much!!!
Now i can recommend, buy and roll out new devices for my family members and friends.
I love Your work and efforts.
K9-mail from F-droid has a strange displaying behavior. The top and bottom bars start blinking frequently. Apart from that, it is usable. I am using the MicroG version installed with TWRP.
If I remember right I need a migration zip to go from unofficial to official? Itās been long ago i needed that, where can i get one for this migration?
I donāt think you need a migration build. Just try a dirty flash.
Thanks. Update is scheduled for Saturday still on unofficial
Off topic: For the transition from CyanogenMod to LineageOS, a transition zip was required AFAIK. In my career of flashing custom ROMs, it was the only time I ever needed to do that.
AFAIK a migration zip was used for passing from 14.1 unofficial to official and 15.1 unofficial to official on FP2. See here:
Edit: Typo
Iām remembering it this way also, migration from unofficial to official, to account for the new keys. Still, it might be possible to ignore the change of keysā¦ Will see tomorrow
Yup, this zip was however specific for my unofficial build to the official one. Wonāt work for this transition. Maybe the maintainer for the unofficial FP3 build could do the same trick as I did back then (probably the zip is still usable and only the values in the script need to be changed).
I canāt test it as I donāt have the device, else I would have helped
I installed the first build and so far itās working very well!
The only problem that I noticed is that I canāt play Ogg audio files (tried the built-in music player and Odyssey). Did anyone else run into this?
I confirmed that the LineageOS built-in music app (Eleven) canāt play ogg vorbis files, although some apps (such as Firefox) were working. The problem appears to be known. I was able to fix it by modifying some of the audio configuration files - it appears the the device was trying to use hardware codecs to play this format which did not work.
Fix will be included in the builds next week.
Hi all, Iām new to FP3 and never ārootedā a device to install another OS like LOS. Is there a good guide youād recommend for getting started? Thank you
Last but not least, is it really worth tinkering with LOS, compared to FPOS?
Rooting the device is something different than installing an alternative OS.
How to do it is explained in the official LineageOS page for FP3.
If itās worth, well, youāve to decideā¦ Youāll quite move away from Google services and will get a community driven alternative to standard OSā¦ And ātinkeringā with it youāll probably learn a lot about your deviceā¦
Awesome, thanks for saving my music collection!
Dirty install went without problems, it seems!
Did you happen to add (t)exfat already for the external sd card, or is it not there yet?
