Completely unable to help but keep in mind the official version is from the last weeks/days. Makes sense that part of the guides are not there I suppose. Read what the next person will be texting.
EDIT: I will probably reuse your idea of backup to SD card. Faster to arrange than webdav and more convenient than external backups. (backups are so important that they should be automated)
Iâm running Lineage official and manually installed microG. Itâs actually fairly easy, you donât need to install it as an add-on during the installation process of Lineage like it is required with e.g. GApps. After youâve completed the installation of Lineage, just follow the instructions here: Installation ¡ microg/GmsCore Wiki ¡ GitHub . Iâd recommend to add the microG repository to F-Droid for easier updates of microG
Sorry, i donât have time to go through that in detail now, but it should really be sufficient to boot into any working recovery, sideload the lineage zip, any addons you like and then reboot. Make sure to verify it installed correctly by reading the output on your phone before rebooting.
If that does not work, you will need to figure out how to get logs, or completely follow the instructions including formatting data.
I just wanted to let you all know that we just merged a few things, including the rolled back wifi firmware, since that seems to have fixed the IPv6 issues, some improvements to the perf stack which should make the device significantly smoother and the microphone patch from the last unofficial build i shared.
The next official build is scheduled for next monday.
I still have a problem with the messages app (latest official).
In the listing view of the messages there are two layers of text. The first one is fixed and the second can be scrolled. The texts are identical, so i am able to scoll the two layers on top of each other so i can at least view the first messages,
Hi, I donât use any mods at all. I canât reinstall cause I want to keep my data, so here are some interesting things I found in the logs :
08-06 00:00:03.858 29634 29691 D CompatChangeReporter: Compat change id reported: 150939131; UID 10106; state: ENABLED
08-06 00:00:03.858 29634 29691 I ColorCustomizationManager: Resetting {}, VIBRANT, home_wallpaper to null
08-06 00:00:03.894 2998 3101 I ThemeOverlayApplier: Won't enable com.android.theme.icon_pack.filled.android, it doesn't exist for user0
08-06 00:00:03.895 2998 3101 I ThemeOverlayApplier: Won't enable com.android.theme.icon_pack.filled.systemui, it doesn't exist for user0
08-06 00:00:03.895 2998 3101 I ThemeOverlayApplier: Won't enable com.android.theme.icon_pack.filled.settings, it doesn't exist for user0
08-06 00:00:02.942 1 1 I init : starting service 'idmap2d'...
08-06 00:00:02.952 1 1 I init : ... started service 'idmap2d' has pid 29707
08-06 00:00:02.952 1 1 I init : Control message: Processed ctl.start for 'idmap2d' from pid: 2283 (system_server)
08-06 00:00:03.937 29707 29707 I idmap2d : Starting
08-06 00:00:03.938 29707 29707 W libbinder.BackendUnifiedServiceManager: Thread Pool max thread count is 0. Cannot cache binder as linkToDeath cannot be implemented. serviceName: idmap
08-06 00:00:03.944 29707 29708 W idmap2d : failed to parse idmap header of '/data/resource-cache/data@resource-cache@com.android.systemui-accent-Jj4C.frro@idmap'
08-06 00:00:03.951 29707 29708 W idmap2d : failed to parse idmap header of '/data/resource-cache/data@resource-cache@com.android.systemui-dynamic-hPZM.frro@idmap'
08-06 00:00:04.003 2283 4862 D OverlayManager: commit failed: cannot enable immutable overlay packages in runtime
08-06 00:00:04.003 2283 4862 D OverlayManager: com.android.server.om.OverlayManagerServiceImpl$OperationFailedException: cannot enable immutable overlay packages in runtime
08-06 00:00:04.003 2283 4862 D OverlayManager: at com.android.server.om.OverlayManagerServiceImpl.setEnabled(OverlayManagerServiceImpl.java:517)
08-06 00:00:04.003 2283 4862 D OverlayManager: at com.android.server.om.OverlayManagerService$1.executeRequestLocked(OverlayManagerService.java:1014)
08-06 00:00:04.003 2283 4862 D OverlayManager: at com.android.server.om.OverlayManagerService$1.executeAllRequestsLocked(OverlayManagerService.java:1055)
08-06 00:00:04.003 2283 4862 D OverlayManager: at com.android.server.om.OverlayManagerService$1.commit(OverlayManagerService.java:947)
08-06 00:00:04.003 2283 4862 D OverlayManager: at android.content.om.IOverlayManager$Stub.onTransact(IOverlayManager.java:529)
08-06 00:00:04.003 2283 4862 D OverlayManager: at android.os.Binder.execTransactInternal(Binder.java:1478)
08-06 00:00:04.003 2283 4862 D OverlayManager: at android.os.Binder.execTransact(Binder.java:1418)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: setEnabled failed
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: java.lang.SecurityException: commit failed
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Parcel.createExceptionOrNull(Parcel.java:3373)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Parcel.createException(Parcel.java:3357)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Parcel.readException(Parcel.java:3340)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Parcel.readException(Parcel.java:3282)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.content.om.IOverlayManager$Stub$Proxy.commit(IOverlayManager.java:979)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.content.om.OverlayManager.commitToSystemServer(OverlayManager.java:367)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.content.om.OverlayManager.commit(OverlayManager.java:396)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at com.android.systemui.theme.ThemeOverlayApplier$$ExternalSyntheticLambda0.run(go/retraceme d216cbf7bd6da5fadd8345fbe3fba450be7b2c711b8b8030e4fc78aee7e619ab:303)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Handler.handleCallback(Handler.java:1070)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Handler.dispatchMessage(Handler.java:125)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Looper.dispatchMessage(Looper.java:333)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Looper.loopOnce(Looper.java:263)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Looper.loop(Looper.java:367)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.HandlerThread.run(HandlerThread.java:139)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: Caused by: android.os.RemoteException: Remote stack trace:
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at com.android.server.om.OverlayManagerService$1.commit(OverlayManagerService.java:957)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.content.om.IOverlayManager$Stub.onTransact(IOverlayManager.java:529)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Binder.execTransactInternal(Binder.java:1478)
08-06 00:00:04.004 2998 3101 E ThemeOverlayApplier: at android.os.Binder.execTransact(Binder.java:1418)
08-06 00:00:04.010 2998 3101 D ThemeOverlayApplier: Executing onComplete runnable
08-06 00:00:04.016 2998 2998 D ThemeOverlayController: ThemeHomeDelay: ThemeOverlayController ready with user 0
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: Timed out waiting for color update
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: kotlinx.coroutines.TimeoutCancellationException: Timed out waiting for 3000 ms
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at kotlinx.coroutines.TimeoutKt.TimeoutCancellationException(Timeout.kt:189)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at kotlinx.coroutines.TimeoutCoroutine.run(Timeout.kt:157)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.os.Handler.handleCallback(Handler.java:1070)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.os.Handler.dispatchMessage(Handler.java:125)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.os.Looper.dispatchMessage(Looper.java:333)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.os.Looper.loopOnce(Looper.java:263)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.os.Looper.loop(Looper.java:367)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at android.app.ActivityThread.main(ActivityThread.java:9287)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at java.lang.reflect.Method.invoke(Native Method)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:566)
08-06 00:00:06.863 29634 29634 W ColorPickerViewModel2: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:929)
Indeed, it worked to update. The issue is just that the first time I didnât sideload the google apps before first boot and then one of the slots stops working.
So, I now have the unofficial version in one of the slots. Should I now update that slot too? Whatâs the best practice?
I installed the new build yesterday, worked remotely today so I was on my Wifi all day long and havenât had a single loss of connection. Continual checks on test-ipv6.com yielded 10/10 every single time.
So Iâd say this works Other than that, the overall feel is very smooth, which is great as well. It now feels like a high quality phone thanks to your high quality work!
