The phone works fine as it should most of the time. I am however mostly connected to Wifi so I do not see when the problem occurs.
At times, when I don’t have Wifi enabled/I am not connected to Wifi, I notice that there is no “network” detected (although it doesn’t state that there is no network, it just doesn’t show the 4G/3G/E symbol next to the network signal strenght icon, which seems to be strong.
A reboot fixes the issue, so I assume it to be a SW issue.
Does switching flight mode on/off solve it as well?
Perhaps you could try disabling the “enhanced LTE mode” in the settings, it is a known workaround for some issues.
Sometimes switching flight mode on/off has solved it. I do not remember though if it solves it 100% of the times or not. Last times I have chosen to reboot for some reason.
I have a similar problem. Due to lockdown I’m usually using Wifi as well.
“Cellular network” icon in the notification panel switches to “no SIM card” and the only way to retrieve network is to reboot the phone.
It happens sometimes 2 or 3 times a day, sometimes everything’s fine for a few days…
I am observing similar/same issue: my internet connection stops to work suddenly while chatting/playing/so on…, the symbol of data connetion (LTE/3G) still persist but no arrows (▲▼) are shown close to it.
Sometimes switching flight mode on/off sole the problems, sometimes after switching FM on i have no internetconnection ( the symbol of data connection is not shown) or i have no network (as if phone can’t find a cell tower). In this last case I usually reboot and everything come back to work properly.
I am not sure about it because during the past 2 months I have never used data nework.
I can compare last update with the previus only for 4 days and during this period i do not remember any annoyance with data network; for sure after the update I remember I had to reboot the phone to solve it at least a couple of times.
An update:
The issue is happening quite often to me (I am not using WiFi just to see it), only this afternoon 2 times.
I made these tests:
1- erased APN and created a new one as described in iliad website. Nothing changed.
2- changed the preferred data connection from “2G/3G/4G (Auto)” to “2G/3G (Auto)” and connection worked again, then I came back and stopped. Now I am under 3G and it is working.
Update: I downloaded a network analyser to see the differences under LTE and 3G. During LTE it seems that Data Activity stays always dormant while under 3G there is movement. Other 2 screenshots. Sorry…
Ah, good finding Pandalf. It might though be simply your network though.
My problem is different. I do not see the “type of network” marking next to the coverage icon.
