Hey! I’m able to download stuff/ accept data via bluetooth, but I cannot send anything from my phone to another device.
Also the bluetooth symbol is grey, when I think it should be blue when turned on.
I’d be happy if you could tell me what to do.
Thank you
I think it is grey when you activated BT and it turns blue only when you currently have an active, already-paired device around (e. g. when you use your BT earphones)
That it is grey means you have nothing paired with the phone at this moment IMHO.
Can you send something to a paired phone? (Pair with another phone and then try to send something.)
No, also not possible.
