Noise cancelling fairbuds xl 2023 vs 2025
I understand that the speakers of the fairbuds xl 2025 model have improved audio quality, but I was wondering if the noise cancelling is improved (by the better audio quality or otherwise) with the new speakers. I’m not a big audiophile and so I’m not too concerned with the audio quality in and of itself, but I do find the noise cancelling to be rather poor (it seems to make only a slight difference when nothing is playing, it seems to improve a bit as it plays audio, with the louder the audio it plays the stronger the effect, but it still leaves a lot to desire imo), so if others have noticed a clear improvement in that regard I’d be inclined to get a new set of speakers
I strongly suggest avoiding the v1 (2023) FairBuds XL, as they had a materials defect causing the earphones to literally physically break. This happened to me. For messy reasons the repairs didn’t work (for me), and I wound up buying the improved 2025 (v2) model, which to-date has not had any problems. Audiophile-wise (I’m one myself), I cannot compare the two side-by-side (obviously), but with the help of the (improved) FairBuds App, either seems Okay. Some other makes work well (the Marshall brand, is quite good if you like the “Marshall Sound”, albeit as its always(?) enabled, in practice those are only for playback; And they have low user-repairability and a poor ecological footprint (as far as I can now recall)).
I dont know the 2023 fairbuds XL, but the noise canceling from the newer version is poor.
