Hi everyone! I recently bought a new battery and back frame for my FP1 (bloated battery problem…) and finally got around to update my OS as well. So far so good - but now my external speaker won’t make as much as a beep… Internal speaker is working, I can make phone calls without problem but I just can’t hear when someone calls… IF I open up the back frame again, what am I looking for? Any other suggestions?
Did you replace the back cover or the midframe?
If it’s the latter, then you should open it again and check if the loudspeaker looks like here on iFixit.
Yupp, I had to wiggle it in place but it worked on the second try! Thanks Stefan
