No mobile data on FP6
As of the title, I have no mobile data on my fairphone 6.
I received my fairphone few days ago and it does not connect to the mobile data network. The sim works for calls but not for internet on the FP6, while it works perfect on my old device.
I followed the support page trubleshooting step by step, but the problem persist.
Did anybody else faced the same issue? Any suggestion?
What software are you running on your FP6? What kind of SIM are you using? Which service provider? Did you use his recommended settings?
Hi Incanus!
I am using android 15. It is a physical sim from a local provider in Spain (Som Vera). I used recommended settings and toggled some options followeing the support page troubleshooting steps.
Solved.
I had to manually configure the APN
