Since the upgrade to Open OS 18.03.1, it doesn’t connect to the LTE network anymore but remains at GSM/EDGE/2G and UMTS/3G.
When I force “LTE only”, it stays offline.
The LTE network of the provider (O2) is known good, as other phones can connect here.
Any ideas?
Cheers,
Daniel
Stanzi
#2
Did you try to switch the sim card to the other slot? I know it sounds stupid, but as far as I know sometimes one slot has troubles with LTE…
OK I figured it! It’s the SIM card. With another SIM card, LTE works fine. D’oh.
Thx anyway!
D.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
