Since several weeks the same problem with my FP5, 3.5 years old. Yesterday we exchanged the USB-C-module (Thanks, Urs!) and now everything works well ![]()
I’m connecting my phone to the only trusted desktop computer I have via USB-A to C and it only charges, no prompt to do anything else, just charging. Using Ubuntu 26.04. I don’t even know what prompt I’m supposed to get (I’m supposed to get a prompt, right??).
Your device has to be unlocked and you need an USB “data cable”. When you connect this then there should appear a notification (in the notification list which you can pull down) where you can change to data transfer instead of the default charging.
I don’t have a dedicated data cable, but it is a regular USB-A to C, not sure if that matters. It should do the job.
It can be a data/charging cable or only a charging cable.
So it is a big difference. And you can’t tell it just by looking what kind of cable it is.
It has to do with the connectors at the end, no? So it should be possible by looking.
A only charging cable is two threaded. A data/charging cable is four threaded.
So you can’t tell from the outside.
Thought you could tell how many threads it has by looking at the end of the cable (Over the metal.).
On my FP5, a USB-C flash drive, a USB-C-to-A OTG adapter (with an SD card), and Android Auto stopped working. Very fast charging also ceased to function. I performed parallel tests using a Nothing Phone and a tablet from a Chinese manufacturer; everything worked fine on those devices. Fairphone support collected my unit, and the USB-C port was replaced in Poland. When I got it back, all the original issues were still present. I reported the problem again, and the entire board was replaced (resulting in a new IMEI), yet the faults persisted. I have now received a brand-new FP5. Based on what I’ve read in your posts, I suspect that the USB-C port either wasn’t replaced at all, or it was replaced with another faulty one. Overall, the support process went well. However, I have since switched to a different manufacturer, as I’m not particularly fond of Fairphone’s software (the removal of the Always-on Display, minor bugs in the GUI, etc.).
I have been trying for a long time to establish a connection between my Windows 11 PC and my FP5, but without success.
I have tried various USB-A and USB-C cables, as well as USB debugging, but still nothing.
When will Fairphone provide a proper update to address this issue—which, based on my searches within this forum, appears to have existed since 2023?
Hello
The issue keeps and will keep reappearing on the forum. The reasons I have managed to identify were several: faulty USB ports, loose connectors, hardware issues, faulty chargers and cables, issues of software compatibility.
To the best of my knowledge, it is not a universal issue and I will not expect it to be addressed with any update.
If/when my phone stops being able to do the data transfer (again), my first suspect would be hardware issue.
I moved your post here.
I doubt this has anything to do with an update, I never had any issues with any FP (incl FP5) with my Windows PC and data transfer
I am unsure if this is the issue, but for me the prompt to switch to data transfer after plugging the cable into the phone and PC was missing.
What worked was to switch the standard usb configuration in the developer options to data transfer. Afterwards (unplug and plug in again) it worked without issues.
That said I would not leave it as default value for security reasons.
