No data connection after update to 1.4,2 and rooting
How did you reflash it? I have them same issue after changing /etc/permissions/platform.xml in a similar way as you did. I reflashed using the Manual installation (using fastboot). All my apps and data are still there, but the network issue persists, too.
Seems like the only option is to boot in TWRP and wipe /data. After doing so the issue seems to be solved. But then I have to set up everything from scratch :frowning:
Reflashing using the manual installation should be no problem. But in my opinion the safest way to change /etc/permissions/platform.xml afterwards is inside recovery mode how I described it under point 4b) in ✏ Update Guide for a modified FP Open OS (with Gapps, Xposed and more).
