Hi, the NFC on my Fairphone 5 stopped working, that was a very embarassing moment at the store. It fails the hardware test (“NFC time out”, after I’ve tried to connect it to my card). As far as I know, the NFC-thingy is built into the battery with the FP5. Would a new battery be the solution?
I really hope I don’t have to send it in again, so I’m willing to just order a new battery, if that is likely to just solve things.
Hey, the NFC antennas are in in the battery, the actual chip is in the mainboard. After shutting down the phone, taking out the battery, maybe carefully cleaning the connecting PINs on the phone and battery with a dry microfiber cloth, putting the battery back in and trying again, a battery COULD be the solution. Sometimes it also simply the NFC devices not connecting correctly and the next time it just works. Also removing the card from the wallet and readding it can be a simple solution.
More often than not NFC not working luckily is a hick up rather than something with the phone being fundamentally wrong. Good luck!!
Hello
I tried checking my NFC with cards and it worked only with one, so perhaps it is a temporary glitch?
my NFC once did not work when I put some other card with a chip into my phone case. It was not even a banking card, but a work ID. Anyway the phone started beeping and refused paying (yes, it was a bit frustrating and my friend had to help me;-) )
if nothing helps, you may also try contacting a local angels to verify whether swapping a battery could suffice.
I sadly am beyond this point. I’ve cleaned the contacts, tried with a variety of different devices (vending machine, cash machine, two different stores). The card/bank also doesn’t seem to be the problem, because it fails the NFC hardware test.
Sadly not a glitch, I’ve tried many things and none of it works.
But thanks for the angels idea - I’ve contacted a friend with a FP5 whom I’ll meet next week, and she’ll allow me to use her battery to do another nfc test. ![]()
I borrowed my friend’s battery for a few seconds today, NFC worked, so I just ordered a new one. Easiest fix of all times.
Same problem for me!
I replaced the battery and NFC is working again ![]()
