I’m silently hoping that the headphone jack produces less noise on the new top module. That would actually be my first reason to buy a new module as opposed to the camera quality.
Can anyone with a new top module test or compare the noise of the headphone jack?
New FP2 camera and new FP2 top module arrived in Germany. Assembly and disassembly of old new modules went smooth, FP2 powerup detect new modules and showed a bluish notification on Android 6. Took a normal picture with the new module but I am not a photography expert, dont axe me any fancy questions ;). Thanks go to the FP2 team and everybody involved. Cheers.
I’ve just installed the new FP2 camera and it works quite well. But I’m unfortunately unable to do any compareable shots as there’s no way to fix the shutter speed and there seems to be a bug in exposure lock on open camera.
But from what I’ve observed so far:
) The view angle seems a bit wider now. Anybody knows what’s the (equivalent) focal lenght of the old and new camera?
) The Hi-ISO capability has increased massively. The level of detail on ISO3200 can compete with the LOD at base ISO on the old camera module. However noise is much worse on that setting of course. Maybe it’s just a less agressive noise reduction (which is great IMO) which again makes it almost impossible to compare.
) Subjectively I’d say that Hi-ISO noise is now better for about 2 stops.
) Dynamic range hasn’t increased as much as I hoped but I can hardly tell without being able to lock the exposure settings. However it is definitely better than before. Maybe half a stop or one and a half?
) White balance seems to be a bit more yellowish now at the same settings.
) Starting the open camera app is slow as hell. With the old module it already was a few seconds. Now it’s about 2-6 sec. (it varys strongly) until I can take a picture. Thats super annoying.
Here are a few full-res test shots (with full EXIF info) I made - four ISO settings from each module, ISO 100/400/1600/3200:
Old module:
New module:
As you can see I wasn’t able to lock the exposure on manual ISO with the new camera. Usually I do this by tapping on a spot on the screen that I want to have exposed right (in this case the little plant on the speaker) before releasing the shutter. Now it seems there’s no compensation in shutter speed for the manually set ISO anymore. Looks like a bug to me.
Hi Fairphone team, I just tried to order the camera but https://shop.fairphone.com/en/spare-parts/fairphone-2-camera-module says “coming soon”. Presumably it has sold out? When will there be new stock available please? My daughter has a Fairphone and I want to buy one for her birthday, which is soon. Once we get her feedback myself and my son will probably upgrade our Fairphone cameras too! Or, is it available in the UK from the Phone Coop? I know they sell the phones but dont know if they do the parts as well. Thank you for your help.
Hello @BenPlumpton this is a community forum. Your best chance to get an answer for your questions and also help to have it delivered in time would be to call Fairphone Monday to Friday 9:30 - 17:30 at +31 (0)20-788 4400.
Mobilflip.de reports that German provider mobilcom-debitel will not only continue to carry the Fairphone 2, but will also offer the new modules in selected shops (no specification yet). No word if modules will be available for everyone walking in or just FP2 mobilcom-debitel customers. Article in German.
SOO glad I just saw this post… I thought I would check and my camera settings were still set to the old resolution - I had been wondering why I hadn’t seen the improvement I had been expecting!!
I wasn’t able to find a different setting except for the resolution. I have no different SD-card either. So the only thing that has changed is the camera.
And yes: it definitely was more than a second before I changed the camera. Chances are that this really is related to my SD card. It’s a relatively fast one, but has 128GB which has potential to slow things down.
Plus: turning on the flashlight from the android swipe-down menu also takes longer now. But it’s below 1sec, so I don’t care all too much.
Where do one set the camera resolution? I am on android 6 fairphone2 os with august patches. Thank you.
P.s. dont worry, found the KB article myself speaking about needing to recalibrate the proximity sensor and the camera detail settings at: https://support.fairphone.com/hc/en-us/articles/115003783546
Have you tried saving the pictures on the internal memory instead, just to check if it’s faster?
My pictures are saved on the internal memory, but it’s still slow with open camera. It seems to be faster with stock camera. Have you tried?
I just noticed that in the shop picture the new top module is labelled FP-REC02.
Ominous indeed, but I have the new bundle, and the parts are labelled FP-CAM01 and FP-REC01 just like the old ones (but they are the new ones, @Fuchur777has some photos here where it is the same).
I don’t use the SD for anything picture/camera-related anyway. I just store my mp3 collection on the SD. And the fact that now it’s much slower than before without changing anything except the camera tells me that it has something to do with the new camera module.
And yes, I remember the stock camera app to have been much faster - at least when I was still using the non-open FPOS, like a year ago. But I never measured the startup time with the old camera module, so I have no objective comparison. Now, with the new module it takes about 1-3sec so start (depends on if it’s still in the RAM or not).
