Has anyone any experience yet in selecting the respective network when using both SIMs?
My question is if it is possible to select e.g. 5G on the eSIM and 4G on the physical SIM. Alternatively: 4G on the eSIM and 3G on the physical one. Reason for my question is that on my current FP2 it was possible to select 4G on the first SIM but not 3G on the second one (I was in a country where 2G has been dismanteled already and was not able to select 3G for the second card → was useless at this time). This question applies also for networks/countires where 3G has been deactivated and only 5/4/2G is available.
Welcome to the forum. As far as I can tell there are no FP4s in circulation yet.
On the FP3 you could get 4G on both SIMs, I think it should be the same on the FP4 and you should get 4G at least on both SIMs I suppose.
This wasn’t the case of the FP2 indeed.
Edit:
It is possible to have both SIM cards on 4G
Source: https://support.fairphone.com/hc/en-us/articles/4405866149393-FP4-Global-Network-Coverage
thanks for this info which gives more security
