Musicplaylist oft data in the sd-card
Hi there,
how I can do something linke autoplay with my music from the sd-card.
I’m sure the solution isn’t really mistery but I still don’t find the Option to do that with Amaze.
:slight_smile:
I’m trying to understand what you mean by autoplay. Could you describe what you are trying to do a little more specific?
Thank for spendung attention.
I already have found the solution.
I found out I can use one oft the preinstalled widgets for this task.
Maybe someone else 'll be happy about who looks for this option. :smirk:
I meaned a playlist or something that playing next songs without a new command through touching the screen.
Sorry for my English skill. :sweat_smile:
@Ravten Are you looking for a music app in order to listen to your music?
I think the “amaze” app is just for managing all files on your phone and sd-card.
There’s a preinstalled app called “Google Play Music” but you can also download other applications in the play store.
Does this answer your question?
Yes, thanks :)
