Murena FP5 desktop mode?
Hello! Can anyone else confirm that desktop mode does not appear to be available on the Murena FP5? Hopefully it is and I just haven’t found it yet. Thank you in advance.
Did you look into developer settings?
No I’ve not. I’ll try reach out to them. Have you got a Murena?
(From what I know, she has not and is using a different custom ROM)
You might have more luck at the /e/ forum at https://community.e.foundation
Update: Done in the meantime :arrow_down:
Partially correct I use FPOS😉
I was just wondering if it is as with FPOS on the FP4 , where the setting for desktop mode is in the developer settings.
