More aggressive roaming?
Hi everyone,
My FP6 (FP6.QREL.16.115.0) generally works very well, but I have one recurring problem. I travel between Switzerland, Austria and Germany very often, and around the borders the phone doesn’t switch to the best available network.
What happens:
  • CH → AT: When I leave Swiss 5G coverage, the phone hangs on to the Swiss network for a long time and has no usable data connection in Austria. If I open the list of available networks, Magenta shows 5G with full bars, but the phone doesn’t switch on its own.
  • AT → CH: It’s the same in reverse. The phone stays on the Austrian network until I’m completely out of range of the Austrian towers, and only then does it pick a Swiss network.
Setup:
  • Provider: Yallo (Swiss)
  • SIM: eSIM generated in 2026
  • Network selection: set to automatic
  • Preferred network type: 5G/4G/3G with 2G enabled
Toggling airplane mode works most of the time but it should do this on its own. When using it in a car (Android Auto) I can’t just toggle airplane mode.
Is there a way to make the phone switch networks sooner when roaming, or is this behaviour controlled by the provider/SIM rather than the phone? Could and should I complain there?
Update: I talked to their ugly little chatboy and then maybe a person but I’m unsure. They said that the are in agreement with all the networking providers and it should work neatlessly. However, then they offered to add a new phone to my plan because the believe that Apple or Samsung have better profiles, whatever that means.
My experience with roaming and crossing borders is the same. It only connects to the “new” network if the “old” network is out of reach or has really low or instable connection quality.
This observation was with all my mobile phones in the past 30 years. So I think it’s not linked to the FP6.
@mike_1312, then maybe check whether an upstream bug report exists at Google’s buganizer instance, for AOSP.
I experienced the same issue when crossing the German border into the Netherlands, as well as when crossing the border from Germany into Switzerland.
With my previous Samsung phone, I had no problems with border crossings. I didn’t even notice the switch between networks. Now, with the FP6, I always have to turn the SIM off and on again. I haven’t tried the airplane mode trick yet, but I will next time, since it is probably easier and quicker.
Ignore when busy. You know you crossed into Germany when the letter E appears at the top of the screen. It has nothing to do with the phone. I now embrace the calm - and get work done :slight_smile:
I’m wondering what is expected? To me it sounds logic it needs a moment to switch to roaming and a foreign network after crossing-border. However its normally not more than very few minutes we are talking about, or? Whats the issue? Anything really important not working?
Important is always relative, right?
Especially annoying when on a call (Signal, Teams, not a “call”), when it clings so hard to the old tower and it takes minutes to switch. This is not a “haha Germany bad” post, in these areas where I am, it’s not E-country, there is 5G available.
It’s also annoying in the car when Android Auto doesn’t receive traffic updates or it’s unable to reroute, or YT Music losing connection and not streaming anymore.
I don’t see anyone else having any issues on the train or bus with me, or in the car when my passengers have different phones. So it looks like a FP6-internal profile not tuned, whatever that means. It’s what my provider’s support suggested.
I expect it to switch to the best available network as soon as possible and not after some minutes when the old tower is out of range.
And I don’t see any general problem with MY FP6. When crossing the border from Germany to the Netherlands an back, all four mobile phones in the car switch the network in the same time window (±5-10s). The devices are FP6, ASUS Zenfone 8, Nothing Phone2a and CMF Phone1. All with vodafone.de SIM.
The same when travelling to/from Austria.
Only the point of time when the network change appears differs from the individual situation: signal strength of the available cell towers, landscape, travelling speed
Ich sehe es ähnlich wie mike_1312: Die GSM-Handys verharren so lange sie können im alten Netzwerk, bevor sie ins Neue wechseln, seit Anbeginn der GSM-Aera. Bei den frühen Geräten konnte man noch eine Liste “bevorzugte Netzwerke” führen, wenn dort nur das heimische Netz eingetrage war loggte sich das gerät bei der Heimkehr aus dem Ausland schneller ins heimische Netz. Dies war damals sinnvoll, da man damals noch horrende Roaminggebühren bezahlen musste. Heute spielt das EU-Intern - dank den Roaming-Verträgen der schweizerischen Anbieter - und der CH zumindest bei der Telefonie (fast) keine Rolle mehr (Bei den Daten sieht es noch etwas anders aus). Doch ich wünschte mir auch, dass diese Handy-Algorhythmen individuell beeinflusst werden könnten.
Would you kindly stay in the topic language which is english in this case?
I do have the same problem with my FP 6+, between Germany, Switzerland and Austria. I live in this area and there was no problem in the last 25 years. Since 2 month I have the FP6 and at this was the moment the problem started. Sometime even if i start my FP completely new, I cant get any connection when i go over the border. I will do some experiment in the future, like described in topic above.
Which provider?
I recently was in the netherlands and had no issues it took a few minutes to recieve the SMS notification to welcome me in the netherlands
What I noticed is. that all who “complain” are using a Swiss network or travel the Switzerland. Maybe it’s linked to this, because they aren’t EU and the roaming works different. Could be an idea.
But to be honest, right now, the control sample is to small. Maybe if more users have this issue, they can tell us which countries/networks are affected.
I often travel to/from Switzerland and I have no problems. But I also think it’s quite expected to have 10s with no internet when the network switches.
Ein paar Sekunden ohne Internet während des Netzwechsels sind ja durchaus normal. Wenn das Handy nach dem Grenzübertritt aber überhaupt keine Verbindung mehr bekommt, selbst nach einem Neustart nicht, ist das schon ein ganz anderes Problem. Ich denke, diese beiden Fälle sollte man getrennt voneinander betrachten.
This would be in general nice :slight_smile:
Also for you please stay in English
I also noticed that border crossings don’t happen as seamlessly or consistently across countries and regions. This is especially annoying when phone GPS is needed in remote areas. Google Maps does a fantastic job of keeping us on track where network coverage is scarce, but in my almost weekly cross-boader travel experience, switching networks at border crossings can be the weakest link, especially if we have to use the airplane mode because then we crash Google map.
Before the FP6, I used BlackBerry (yes, until 2026!), with the same SIM/provider and in the same cars, and experienced similar issues, more frequently and for longer. When traveling with my partner, who has the latest iPhone, we often joke about “which phone will do worse this time”. We actually tend to run Google Maps on both phones as a mitigation strategy when together, which totally confirms the pain point. Guess what, the newer iPhones aren’t often worse (vs. the one launched 4y ago about, same SIM/provider), and he gets angrier than I do!
Some may argue that downloading the recent Google Maps´ feature that allows more map data to be stored directly onto the device, could help with navigation in remote areas. Possibly a good way to address this pain point.
Das tut mir leid, aber ich befürchte, bei meinen Englischkenntnissen wäre dies eine Zumutung.
DeepL: I’m sorry, but I’m afraid that, given my level of English, this would be asking too much of me.
You can use deepl as you did above. No problem at all. Else you always have the option to open a seperate topic in german or any other language you want.
