I have just installed the latest OPEN OS update on my FP2 and after this sending images as MMS does not work any more, it just keeps sending and sending ans sending with no end.
Also in the Image galery does not show the options menu for single images any more, the dropdown menu I try to use to find out about properties of certain images stays all black
Reg MMS I think you need to check the APN settings.
Which Gallery do you use?
I use the gallery from the OPEN OS
