I plugged a new microSD card:
SanDisk classe 10 32gb UHS-1 ultra microSDHC
but when I go in parameters -> Stockage -> SD card, the two options ‘install’ and ‘format’ are not active (in light grey)
this cards works perfectly on a computer (Ubuntu) with a USB card reader
I tried another card, also SanDisk, it did not work either.
Of course, I cannot see my SDcard in Amaze
I tried to reformat my microSD in ubuntu using FAT file system, without any success in the FP2
Did I miss anything, do you also have troubles, is my FP2 defective for the microSD plug ?!?
Thanks for your help,
Manu
