I thought I had a mobile… but the microphone is mute
non-google lineageOS VErsion. I guess Fp 2 22.08.0-rel 0
typing on the screen does not work - it ALWAYS shows the mute symbol
the people only here me, when I put on the loud-speaker
deleting cache (where ?) does not work in the settings…
anyway they hear me when calling with the loud-speakers on
Fp 2 22.08.0-rel 0 is not LineageOS, so what exactly are you running on your FP2?
At least it was in May.
No need to guess … Settings - System - About phone or Settings - About phone (don’t know exactly where it is in current Fairphone Open OS) should have the answer.
When using the loud-speakers it also shows the mute symbol?
Does the microphone work in other use cases?
Maybe the microphone on the bottom module is broken?
when using the loud-speakers it also shows the mute symbol - yes
they only hear me when I put on the loud-speaker icon - what other cases
perhaps yes… there are two microphones ? I opened it - tried to fix the screws of the microphone
Same problem… I only hear my echo on the mobile - nothing on the phone I called.
also thought that some app like signal would block the microphone - but nope
Ok
- I understand that when calling via phone you see the mute symbol when in normal mode and in speaker mode and called party can’t hear you
- What are “other cases”? E.g. voice call with signal? In this case the called party can hear you when are in speaker mode but not in normal mode?
- Yes, the phone has two microphones, one for normal mode, one for speaker mode
- The problematic microphone on the FP2 is the microphone used for normal mode
- did you try the microphone test function of Fairphone checkup tool?
thanks for the hints - I disassembled and only saw the microphone with the micro-symbol
sure: I should call someone via Signal
where do I find the test function - in settings ?
I’ll try all that again this weekend
Thanks again
Well, we still haven’t finally claryfied which OS System you’re using. So it’s hard to say.
If you’re using Fairphone open then I assume it should still be found in settings.
If you’re using the F-Droid app store then you’ll find the appropriate app Fairphone checkup there.
