what other folders do you have under /storage ?
My situation now is that I have re-create the folder /storage/emulated/0 and /storage/emulated/legacy but this does not help.
Things are noremal when I use another sdcard, even though the file system appears to be in order.
tried adb logcat, these are the last words of my device before it goes into soft reboot:
I/sdcard ( 160): [1] SETATTR fh=0 valid=1 @ 41356148 (obb)
E/cutils ( 4515): to chown(/storage/emulated/0/Android/obb, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=6 @ 41356148 (obb)
I/ActivityManager( 2694): Start proc org.fairphone.launcher for activity org.fairphone.launcher/.Launcher: pid=4515 uid=10017 gids={50017, 1015, 3003, 1028}
I/sdcard ( 160): [1] SETATTR fh=0 valid=1 @ 41356070 (0)
E/cutils ( 4528): to chown(/mnt/shell/emulated/0, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=6 @ 41356070 (0)
I/sdcard ( 160): [1] SETATTR fh=0 valid=1 @ 413560b8 (obb)
E/cutils ( 4528): to chown(/mnt/shell/emulated/obb, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=6 @ 413560b8 (obb)
I/ActivityManager( 2694): Start proc com.google.process.gapps for content provider com.google.android.gsf/.gservices.GservicesProvider: pid=4528 uid=10057 gids={50057, 3003, 1007, 1028, 1015, 1006, 3002, 3001, 2001, 3006}
I/sdcard ( 160): [1] SETATTR fh=0 valid=1 @ 41356100 (Android)
E/cutils ( 4528): to chown(/storage/emulated/0/Android, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=6 @ 41356100 (Android)
E/cutils ( 4528): to chown(/storage/emulated/0/Android/obb, 0, 0)
I/Crashlytics( 4515): Initializing Crashlytics 1.1.11.10
I/GservicesProvider( 4528): Gservices pushing to system: true; secure/global: true
I/PowerManagerService( 2694): setBrightness mButtonLight 0.
I/SurfaceTexture( 2654): Toast destroying EGLImage dpy=0x1 img=0x41c79490
I/BufferQueue( 2654): Toast consumerDisconnect
I/BufferQueue( 2654): Toast ~BufferQueue
I/Launcher( 4515): Create Launcher
I/ActivityManager( 2694): Process android.process.acore (pid 2888) has died.
I/SurfaceTextureClient( 2798): [STC::queueBuffer] (this:0x5e0df140) fps:0.75, dur:2667.69, max:2179.28, min:488.41
I/BufferQueue( 2654): StatusBar [queue] fps:0.75, dur:2667.75, max:2179.31, min:488.43
I/BufferQueue( 2654): StatusBar [release] fps:0.75, dur:2665.06, max:2090.21, min:574.85
I/SurfaceFlinger( 2654): [SurfaceFlinger] fps:28.581194,dur:1084.63,max:413.12,min:11.50
E/cutils ( 4554): to chown(/mnt/shell/emulated/0, 0, 0)
E/cutils ( 4554): to chown(/mnt/shell/emulated/obb, 0, 0)
E/cutils ( 4554): to chown(/storage/emulated/0/Android, 0, 0)
E/cutils ( 4554): to chown(/storage/emulated/0/Android/obb, 0, 0)
I/ActivityManager( 2694): Start proc com.google.android.gms for service com.google.android.gms/.ads.identifier.service.AdvertisingIdService: pid=4554 uid=10057 gids={50057, 3003, 1007, 1028, 1015, 1006, 3002, 3001, 2001, 3006}
I/WifiStateMachine( 2694): fetchRssiAndLinkSpeedNative, newRssi:-38, newLinkSpeed:54
W/NotificationService( 2694): Object died trying to hide notification android.app.ITransientNotification$Stub$Proxy@41860838 in package com.keramidas.TitaniumBackup
I/MultiDex( 4528): VM with version 1.6.0 does not have multidex support
I/MultiDex( 4528): install
I/MultiDex( 4554): VM with version 1.6.0 does not have multidex support
I/MultiDex( 4554): install
I/MultiDex( 4528): MultiDexExtractor.load(/data/app/com.google.android.gms-1.apk, false)
I/MultiDex( 4554): MultiDexExtractor.load(/data/app/com.google.android.gms-1.apk, false)
I/MultiDex( 4554): loading existing secondary dex files
I/MultiDex( 4528): loading existing secondary dex files
I/MultiDex( 4528): load found 2 secondary dex files
I/MultiDex( 4554): load found 2 secondary dex files
I/MultiDex( 4554): install done
I/MultiDex( 4528): install done
W/ADB_SERVICES( 161): terminating JDWP 4515 connection: Try again
I/ActivityManager( 2694): Process com.android.vending (pid 4502) has died.
I/SurfaceTextureClient( 2798): [STC::queueBuffer] (this:0x5e0df140) fps:0.21, dur:4751.92, max:4751.92, min:4751.92
I/BufferQueue( 2654): StatusBar [queue] fps:0.21, dur:4753.29, max:4753.29, min:4753.29
I/BufferQueue( 2654): StatusBar [release] fps:0.21, dur:4756.30, max:4756.30, min:4756.30
I/SurfaceFlinger( 2654): [SurfaceFlinger] fps:0.210174,dur:4757.97,max:4757.97,min:4757.97
I/WifiStateMachine( 2694): fetchRssiAndLinkSpeedNative, newRssi:-39, newLinkSpeed:54
W/ActivityManager( 2694): Exception when unbinding service com.google.android.gms/.ads.identifier.service.AdvertisingIdService
W/ActivityManager( 2694): android.os.DeadObjectException
W/ActivityManager( 2694): at android.os.BinderProxy.transact(Native Method)
W/ActivityManager( 2694): at android.app.ApplicationThreadProxy.scheduleUnbindService(ApplicationThreadNative.java:843)
W/ActivityManager( 2694): at com.android.server.am.ActiveServices.removeConnectionLocked(ActiveServices.java:1396)
W/ActivityManager( 2694): at com.android.server.am.ActiveServices.killServicesLocked(ActiveServices.java:1678)
W/ActivityManager( 2694): at com.android.server.am.ActivityManagerService.cleanUpApplicationRecordLocked(ActivityManagerService.java:11416)
W/ActivityManager( 2694): at com.android.server.am.ActivityManagerService.handleAppDiedLocked(ActivityManagerService.java:3169)
W/ActivityManager( 2694): at com.android.server.am.ActivityManagerService.appDiedLocked(ActivityManagerService.java:3266)
W/ActivityManager( 2694): at com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied(ActivityManagerService.java:920)
W/ActivityManager( 2694): at android.os.BinderProxy.sendDeathNotice(Binder.java:436)
W/ActivityManager( 2694): at dalvik.system.NativeStart.run(Native Method)
W/ActivityManager( 2694): Exception when stopping service com.google.android.gms/.ads.identifier.service.AdvertisingIdService
W/ActivityManager( 2694): at android.app.ApplicationThreadProxy.scheduleStopService(ApplicationThreadNative.java:872)
W/ActivityManager( 2694): at com.android.server.am.ActiveServices.bringDownServiceLocked(ActiveServices.java:1323)
W/ActivityManager( 2694): at com.android.server.am.ActiveServices.removeConnectionLocked(ActiveServices.java:1404)
W/ActivityManager( 2694): Scheduling restart of crashed service com.android.vending/com.google.android.finsky.services.ContentSyncService in 162678ms
I/ActivityManager( 2694): Process org.fairphone.launcher (pid 4515) has died.
I/AlarmManager( 2694): reset poweroff alarm none
E/SystemServer( 2694): ServerThread has no response for 15 sec. Dump stack trace…
I/Process ( 2694): Sending signal. PID: 2694 SIG: 16
I/dalvikvm( 2694): threadid=3: reacting to signal 16
E/cutils ( 4576): to chown(/mnt/shell/emulated/0, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=1 @ 413560b8 (obb)
E/cutils ( 4576): to chown(/mnt/shell/emulated/obb, 0, 0)
I/sdcard ( 160): [1] SETATTR fh=0 valid=6 @ 413560b8 (obb)
E/cutils ( 4576): to chown(/storage/emulated/0/Android, 0, 0)
I/sdcard ( 160): [0] SETATTR fh=0 valid=1 @ 41356148 (obb)
E/cutils ( 4576): to chown(/storage/emulated/0/Android/obb, 0, 0)
I/sdcard ( 160): [1] SETATTR fh=0 valid=6 @ 41356148 (obb)
I/logwrapper( 118): /system/bin/6620_launcher terminated by signal 9
