Malware or built in vulnerability- please help me resolve this
Please help me. I don’t know if I have a horrible bit of malware on my phone or if it’s an inbuilt vulnerability.
Symptoms appear from the moment of start up and even after I’ve factory reset my phone. I have tried to change all my settings to as private as possible, and have disabled all the apps I possibly can, but it’s still there.
I’m sure that sometimes when I try and disable an app, when I open it, I get a split second where I can change it but then I can’t.
Other symptoms are that I constantly hear a very loud high pitched whistle coming from my phone, which is most active from midnight until 10am.
I know that my camera, mic and location are also affected, as well as my movement, light, camera, usb and speaker sensors.
My message app and WhatsApp is also affected, as well as when I had FB and Instagram.
I also get the impression that the smart speaker detector is getting tapped into as well (it feels like my phone is releasing pulses of something, where the heat from them is hitting me, especially when I make a noise and move around near my phone.
Unfortunately, I do not know how to remove such an annoyance (I’m too scared to go into the root and brick my phone), so I was hoping that you all could help me please.
I have also tried Malwarebytes, Avast, CCleaner and other antivirus softwares.
Thanks so much for your help in advance :slight_smile:
Not joking, but do you have a carbon monoxide detector? Also have you ran any anti virus scan on the phone like malwarebytes?
I don’t have gas in my building, but yes, good thinking for general safety
Yes, I have tried Avast, Cleaner, malwarebytes amongst others with no luck unfortunately.
