I would love to be able to make my Fairphone silent for everything except phone calls. So no noise or vibrations when I get an email or a text, or when I start my Fairphone up, or when I shut it down - nothing, nada, nichevo, zero. But I’m finding it really hard. There’s always an unexpected beep or a burp. Can anyone tell me an easy way to shut all the noises and vibrations off please? I just want my Fairphone to ring when someone calls me - that’s all.
Don’t know if you can disable all sounds/vibrations, but most of them.
In System settings>Audio profile you can disable notification sound (choose ‘none’ from the top of the list) and also disable touch sounds/vibration. Tap the ‘levels’ icon under 'Predefined profiles’
For e-mails you may have to adjust the settings in your mail client app.
The only thing I haven’t been able to get rid of is the vibration that occurs when turning off the phone but I can live with that.
Ok great – I think you may have cracked it in terms of the odd burps and beeps. In Audio Profiles there’s an icon to the right of General which gives more settings. In there under Notifications it has a Default notification sound which was set to Proxima. Now set to none. I guess that’s maybe what you meant. Anyway thanks. And yes, I can also live with the vibration when I turn the phone off! Thanks.
