Any suggestions for how to make the …ear/internal/bottom speaker work again?
When receiving or making a call without using bluetooth or the loud-loudspeaker (Which I gather is referred to as top speaker?) Otherwise I can’t hear anything, but the microphone works.
I tried the trick with Accessibility Settings > Mono > balance all the way to the left and it didn’t fix the issue. Do I need to do a reboot?
My suspicion is that its a SW problem, not a HW. Kind of like if the speaker jammed in switched off position because of using bluetooth headset, all though I turned off bluetooth.
FP bought January 22, Buildnumber: FP4.SP2G.B.079.20230624
